Hello,
just go on the display to the filament an then touch the three points on the right top. There should be the option move or something.
With this option the extruder gets hot an you can move the filament with the two arrows in both directions.
I hope i could help
1
ultiarjan 1,219
The way I do it manually heat the core by going into the menu and set the temp (in the menu the dots on the top right corner, out of my head, not near a machine now) and manually push fillament (open lever of the feeder and just push)
I assume there's also a move material function in the menu somewhere but can't check now and never use it myself.
