Hi @AndersK,
Thanks for reporting this. I have attache your log file to an internal ticket with the team that works on Connect. Although we're quite busy at the moment we'll be sure to investigate your problem and try to reproduce it.
- 2
Thanks.
As long as it works through SD card I'll wait patiently 😉
@ctbeke Dont know if this is useful for you but had the machine turned off a longer period last week (thunderstorms and several power outages). When I restarted it I could see it had renewed the IP adress and now I can connrct to the job queue again.
Hi @AndersK,
Great you're up and running again! We'll keep our internal ticket around as it's clearly a bug (to us).
Chris
- 3 months later...
An observation, every time I abort a print it goes into this state. Only thing to recover seems to be a full power down.
nallath 1,120
Could you share the logs from your printer?
Alternatively, you could try to do a full factory reset.
