Cura connect problem?
AndersK
Posted · Cura connect problem?
Suddenly I cant access the print queue, neither from the monitor in Cura nor through browser.
I can access the default page through the browser and read temperatures so I know I'm connected.
Printer is connected through LAN cable.
I believe I have the latest firmware image.png.a4117c7b8629d8ffa638e8b2f84f3653.png
Have tested both Cura 4.0 and 4.2.1, same results
Trying to access print jobs through browser ends with error message "502 Bad Gateway"
Cura says there is nothing in queue but I have sliced and sent job over network.image.png.c20cbbd69b0de40f8f774a4d5be5c2da.png
I have done a Cura connect reset from the printer
Also hard reboot by shutting off power but nothing seems to work
Only option now to print is through USB flash drive.
Any ideas what to test?
    Hi @AndersK,
    Thanks for reporting this. I have attache your log file to an internal ticket with the team that works on Connect. Although we're quite busy at the moment we'll be sure to investigate your problem and try to reproduce it.
    • Thanks 2
    @ctbeke Dont know if this is useful for you but had the machine turned off a longer period last week (thunderstorms and several power outages). When I restarted it I could see it had renewed the IP adress and now I can connrct to the job queue again.
    Hi @AndersK,
    Great you're up and running again! We'll keep our internal ticket around as it's clearly a bug (to us).
    Chris
    An observation, every time I abort a print it goes into this state. Only thing to recover seems to be a full power down.
