Thanks @nallath - that is what i feared 🙁
So I start from scratch with the predefined profiles, integrate my defaults (like Combing-Not in Skin, Initial Layer Expansion ...) ,give it a go and add some finetuning.
You're right, some Settings were Material-Specific (like a slow speed for Layer Adhesion) and others depend on the printer (like slow speed for aesthetics). Sadly sometimes i dont remember, what parameter i changed months ago and why. (Note to myself: keep a log!)
Thanks!
nallath 1,080
Short answer; Nope, sorry, this is not possible.
Longer answer: Still not possible, but there is a fairly good reason for it. A lot of the changes that you can make greatly depend on the printer. Lets say that that you changed the wall speed in your profile (30 mm/s on UM3) to be 36 mm/s. The default for the S5 is 45 mm/s. If you override that value, you'd probably not quite get what you meant (eg; Did you mean an absolute value of 36? Did you mean "20% faster than what the default is" or did you mean "default + 6"). As there is a pretty complex interplay of settings, it's rather difficult to just port those settings (We could just make it so that it overrides them, but it's very unlikely that it gets the results that you want).
