Posted · what version of cura can I use
If you have the 32 bit version of windows 7, Cura 2.3.1 will be the latest version that runs. That version too will tell you there are updates, since it is about 3 years old. In both 15.04.6 and in 2.3.1, you can turn off the check for newer versions.
    11 hours ago, Casper75 said:
    am running windows 7 and was using  version 15.04.6 and I always click out of update to a new version. Ever since then I have not been able to get any version to work.
    I don't understand.  It works and it doesn't work?  Can you explain again?
    15.04.6 is old but it is a good version.  It should work fine on windows 7.
    15.4.6 worked just fine , when I upgraded Cura would not load . It kept closing as soon as I click open file . I uninstalled it went back to find the old Cura and it is not available for download anymore
