The print core do cool down and all three fans in the head shuts off (min do anyway, can't say if its normal?)
As fare as I can tell the fan from the electronics down next to the power cord also goes into idle. don't know if there are other fans on the printer.
(fan bracket is only open to show that the fan have stopped when paused. also the two on the sides has stopped, can't take a photo of that though 😉)
I wouldn't say that the z-screw is decidedly dirty?, maybe it's the video quality. if you are referring to the dark color it has always ben that way.
Smithy 753
Maybe I am wrong, because I don't do it often, but normally when you pause a print, the print core remains at temperature, or not? And if it remains on the temperature, then also the front fan runs. And for me it sounds like a fan, but that could also be caused by the video.
BTW: You should clean your Z-screw 😜
