The bottoms of my parts generally look like these below. They seem to be squeezed considerably more into the glass, thus the nozzle being closer to the glass. If you could try that, it might improve overall bottom quality (if that would be desired).
Concerning your very irregular corner: in addition to the possibility of the glass in that area being non-flat or greasy, as smithy says, I am wondering if this is the begin/end of the layer lines, or the landing/take-off zone if printing multiple parts? In that case I could imagine that the starting and stopping of the extrusion would cause irregularities such as little blobs or a bit of underextrusion?
Or maybe a combination of all these?
Try watching it closely while printing, through a good magnifying glass, or a macro camera lens. If the sausages would curl up in that irregular corner, it is probably poor bonding or a greasy surface, and/or a too big distance.
Notes:
- All printed on an UM2, with 0.4mm nozzle, 0.1mm layer height.
- The orange cross was a warping test with huge overhangs and a very small bottom area, sort of an inverted prism, so it came partially loose and warped a bit.
- The first 3 models are colorFabb PLA/PHA, the last transparent grey/green ones are PET.
Smithy 753
This corner looks generally a bit strange. I would say that your bed is not very well leveled, but the S5 make the active leveling, so this could not be the reason. So maybe your glass is not really flat? You see it in the whole corner, that the first layer is not squished into the glass as on the other corners. (or maybe it looks like that only on the photo)
Another issue could be that the glass was not clean enough, some grease from the fingers or something like that.
You could try to turn or position the model on another place on the glass, to see if it makes a difference and if the problem is only in that spot.
