Thank you for your post. I replaced the nozzle thinking maybe something was sticking. I thought I had it fixed. No such luck. I keep the Firmware updated anytime there is a new one available. I have this feeling that the support nozzle oozes a little and throws of the leveling for that nozzle. I usually open the extruder motor and retract the material until it finishes leveling. It's pretty time consuming. It usually happens when I'm pressed for time. 😞
Thanks again.
jones4642 0
Not sure if this is the same problem, but it sounds like a fairly common problem on the S5. Many of us have had issues where the support material oozes during the active leveling process. The problem is that if it is extruder 2 then it is mostly hidden from view during the long leveling process for extruder 1. It just takes a small bump of material to completely thrown off the leveling. If this happens, the nozzle will be too far from the plate and the support material on the first level will not stick.
Interestingly, I have two S5s, and only one of them has really suffered from this. Every time I would start a job, I would end up aborting 3 or 4 times until I finally got a good level (hint - if you see the problem during leveling and abort before the leveling finishes, it is pretty fast. If you wait until leveling is finished, abort takes several minutes). This printer had older FW. I just updated FW, and at least on the first print, it seemed to be fixed. Will see if this was a coincidence.
