Thanks @burtoogle. Saved properly this time! Sorry. Please find attached.
I tried using Top/Bottom line directions [0,90] but that did not influence the direction of layer 41.
Wowzers! That's a scary long and bunch of detailed settings right there! Thank you @burtoogle I guess because it's in Experimental the issue I reported has already been recongnised and will trickle down to default behaviour in a future release ?
burtoogle 508
Hello @td1, I need to see the project file so I can see the settings you are using. Please do File -> Save (not Export) and attach the resulting .3mf file to this thread. Thanks.
