Currently I am not really understanding why it stops after processing the first lines of the new iteration.
I will create a small test file and then try if it is the "padding thing". I would understand it, if it stops right after it, but after heat up is strange for me.
geert_2 556
I don't know much about gcode, and even less about firmware, so this is just guessing.
Could the problem be that "padding thing", that you see earlier in the gcode, at the end of the normal file? Try copying and inserting that padding at the end of your push-off sequences too?
Apart from that, I think any resetting or homing is done at the start of a new print job, just like any normal print. In normal use an UM2 can start from whatever situation it was left in (warm/cold nozzle or bed; head or build-plate sitting anywhere), so that shouldn't cause problems I think?
