Good decision and now you have the possibility to use the adhesion sheets on one glass without it bothering you with other prints. Very handy if you often print different materials.
1
If you have an oven, for example to dry filament, you could also pre-heat the cleaned glass in there. This should reduce the warming-up time a bit.
This is just a theoretical idea :-) I never tried it myself, since I never take the glass out of my printer: I let it cool in the printer until the models pop off, then wipe the glass with a tissue moistened with salt water, and start the next print.
Smithy 1,131
Of course, an additional glass plate makes sense, so you can continue printing without having to wait. I do the same.
Also, you should have a second glass plate anyway, so you have a replacement if one gets broken.
Carla_Birch 115
I personally have 4 glass plates for my S5, 1 i keep as a spare should one break or chip. The other 3 i print with, 1 in the printer printing, one with the last print on cooling down to be removed and the other all clean and ready to go in the printer when the next prints done.
dupton 0
Cheers ! I just ordered 2 spares from https://www.makerpoint.nl/en/print-table-glass-s5.html.
Thanks again, Dermot
