500 hours is not much. It's around when you need to change the teflon part.
Expect to have to change that part every 500 hours. It's a consumable like filament.
The um2 will be less hassle, less learning curve, and slightly better quality and make you happier but the um3 will be a little more flexible with the PVA option. More learning curve for the UM3 (e.g. how to dry PVA and keep it dry). More things that can go wrong. But both of these printers are workhorses that will work hard and for years.
I use my um2 printers 95% of the time but when I need PVA support, it's nice to have available.
Smithy 1,088
The decision depends strongly on your requirements, but in short, if you don't need dual nozzles, 2 colors or PVA as support, then without thinking long about the 2+. I have a UM2Go, a UM3 and an S5 and recently bought a used 2+. Why? Because the printer simply prints very beautifully and, above all, dimensionally accurate.
Moving parts found on Thingiverse, I couldn't print with the UM3 and S5 at all and if then only with much effort to adjust the settings so that these parts are not fused after printing. With the UM2+ I print with default settings and it comes out perfectly.
Both are very similar in terms of maintenance, but I'd say it's a bit more effort with the UM2+, since the PrintCores on the UM3 are already a fine thing.
Dual print or with PVA support sounds good, it is, but don't forget that PVA is very expensive and takes forever to dissolve. Furthermore, PVA is very sensitive to humidity, which means the roll should be kept airtight and if you have longer prints, you should put the spool in a dry box while printing.
I don't want to make the UM3 bad, but it can't compete with the UM2+ in terms of print quality and dimensional accuracy.
I would therefore clearly recommend the UM2+.
Hatim 0
Thanks a lot, your reply is really helpful.
The buyer says that the printer has around 500 hours of printing. I hope it's okay, right ?
