Can't install new firmware T2 T3 LED FAN
superflyguy1973
Posted (edited) · Can't install new firmware T2 T3 LED FAN
My Ultimaker 2 has worked perfect ly for  years with exception to the led which had blown the T1 or T2 transistor.
so i replaced them both and also T3 as it was the same the light now work perfectly. however every time i tried to print or move the bed of print head
i  would get a ER06  or ER05 or ER07 i have tested the stop switch and my connection sereral time and all it fine.
after reading a few posts it suggested reinstalling the firmware , unfortunately it now thinks its the first time i've used the machine
and want to calibrate the bed but keep coming up with the errors messages i have tried to connect it the cura via a usb cable but it dose not detect the printer while it stuck in the
calibration mode Help i understand you cannot install the firm ware via SD card.
Jason
Edited by superflyguy1973
    Posted · Can't install new firmware T2 T3 LED FAN
    Did you perhaps install firmware for another printer? You say you have the UM2 and installing firmware for a UM2+ could show this behavior.
    Which Cura version are you using? We are now at Cura 4.3, but I remember about a year ago there was a bug in Cura where firmware versions for the UM2 and UM2+ were mixed up.
    Instructions for re-installing the firmware on a failing UM2 printer
    The newer versions of Cura are being 'nice' to your printer and that's why they fail in programming.
    In order to start the programming process, Cura has to reboot the printer. That's what older versions of Cura did when you connected the USB cable. Disadvantage was that when you were printing and you started Cura, then your multi-day print would reboot as well.... Oops.
    So, now Cura is nice to the ongoing print process but as a consequence fails to program a printer that's stuck.
    Your workaround is to use another program for programming the printer.
    One option is this old version of Cura: https://software.ultimaker.com/cura/Ultimaker_Cura-15.04.06.exe
    There are other programs as well, but I haven't done this since long so are not aware of the current situation. Look for programs that can program an Arduino AtMega 2560 board
    The UM2 firmware is a *.hex file and is included in the Cura program directory.
    For the UM2+ a release candidate for the next official version can be downloaded here: https://github.com/Ultimaker/UM2.1-Firmware/blob/UM2.1_JarJar/releases/beta/MarlinUltimaker2plus_20181007.hex  (right click on link, and then 'save link as').
    T1 and T2 are BC817 NPN transistors.
    T3 is a BC807 PNP transistor
    So glad Ultimaker provided the schematics so people will study them ....   🙄
    https://github.com/Ultimaker/Ultimaker2/blob/master/1091_Main_board_v2.1.1_(x1)/Main Board V2.1.1.pdf
    T3 indirectly switches on the 24V for the motors and the bed. So with a wrong type of transistor here it explains the wrong behavior in your printer.
