Thanks for your post. Yes i think also that this is a cura failure.
1) yes i used the second one. No i redesigned it and cut off the top, and exported it again as stl.
2) i will test it tomorrow and give you a feedack.
3) with the original ultimaker pla i can go down to 215. With 210 the lines will not stick nice together so i need to go up to 215. I tested it with 60mm/s, should i go down there.
Thanks.
gr5 1,872
I think this is a cura issue, not a UM2 issue.
1) The square (squarish) vase. There are 4 STL files. Which one did you use? Normally I would recommend one of the first 2 and tell you to uncheck the "solid infill top". Is this what you did? Be aware that if you do this there will be ZERO retraction because Cura doesn't retract *inside* prints. So you if you want retraction to work, instead use "thickwall" or "3mm wall".
2) You shouldn't have this issue with this other "stratum" vase. In Cura, after it slices, look at the vase in layer view. Layer view shows a blue line for non-extruding moves but for retraction it additionally shows a short vertical line segment. Look for those to see if Cura is in fact doing retraction. It probably *is* doing retraction but if not, show us a screen shot of Cura where you think it should be retracting yet it isn't.
3) Even with retraction occurring, you can still get strining. Try printing MUCH slower. Try 1/3 the speed you are printing now. Also try as low a temp as you can go. Maybe 190C. Or maybe that is too cold for your filament. Both slowing down and cooler temperatures -- these both reduce stringing -- see first photo here:
http://umforum.ultimaker.com/index.php?/topic/1872-some-calibration-photographs/
