Thanks! That did the trick.
One last question: is there a way to keep the printer printing while removing the USB cable?
UM2 - printing via USB
40 minutes ago, MironT said:Thanks! That did the trick.
No, since (if I understand this correctly) Cura is directly sending the G-Code instructions to the printer in real time if you're printing over USB.
When printing via USB that way, @P3D is correct. Also, be sure to set the PC to never go to sleep.
if you want to not be tethered like that, you can get a Raspberry Pi and install Octopi, the Octoprint version built for the Pi. This runs as a 3D Print server and there is a Cura plug-in to let you print directly to it via the network. When I set mine up, I didn’t have luck connecting it via hardwired Ethernet, but it worked fine using WiFi with a little USB WiFi dongle.
- 1
tinkergnome 927
in short:
"Ultimaker" gcode flavor does work only for prints from sd-card.
If you want to print via USB - change "GCode flavor" to "Marlin" (machine settings in Cura)
important difference:
Material settings on the printer (temperatures and retraction settings) are not longer used. Everything has to be configured in Cura.
