Hi thanks, I managed to get it working. It appears it wasn't manifold and I also had a few other glitches I didnt spot. Thanks for the input. Its currently printing so I hope it works out ok. Cheers, P
Thank you for clearing out that there were problems with your model.
I printed it with above mentioned changes and it worked, too. There was only a little amount of stringing and a little debris inside. I can attach pictures if you like.
Emerald 1
I imported your model and cura indeed doesn't recognize the interior space.
I set the infill to 0% and the top and bottom layers to 0mm. I sliced on fine- 0.1mm with generic PLA in a 0.4 AA core.
Hope this works out for you as I didn't try to print it.
