Thanks, in ordering regular white PLA and 0.2 print head.
Stefania Dinea 101
For a safe bet 1.2 top bottom layer and wall thickness- min 5% infill and i use a skirt not a brim
Edited by Stefania Dineathank you fellow architect.
1
@Stefania Dinea , a skirt doesnt seem to do anything other then draw a separate outline. Is that really better than a brim?
Stefania Dinea 101
@BiMNrd Yes and no, you will already have a like brim created by the base of the PVA - you use the pla skirt to extrude some material before the pla print starts, so you can check if it extrudes correctly and to clean the core of pla residue - hope this makes sense.
Edited by Stefania Dinea-
1
@BiMNrd the skirt lets you visually confirm that your bed is level and that a good initial layer is being laid down. If the skirt looks much thinner on one area, that is a good indication the bed is too high (too close to nozzle) in that area
1
1
Great, I printer a small test model yesterday.
I did it at 0.1 layer height with the 0.4 core. Worked well enough I dont think I will used the 0.2 core I ordered.
I used a brim and 5 hr later it come out. Everything good so far. Loving this printer, it is a little slow though (5hrs) compared to my other abs printer.
Cant wait until I get the white PLA on Monday to reprint it "full size"
BiMNrd 11
Thanks, so lets say I want to use UM materials this time. Pla or tough pla?
Have you tried any of those?
Stefania Dinea 101
@BiMNrd i usually use ultimaker pla but I have tried tough to print some sockets wall mounts in tough - i would recommend tough for such things.
