Here it is for the rachet
Two suggestions for the ratchet:
1 - reduce the max comb distance with no retract to a much smaller value, i.e 5 or 10 rather than the 30 it is now.
2 - try not printing outer walls first (not sure about this, maybe worth trying.
21 hours ago, burtoogle said:Two suggestions for the ratchet:
I can try changing a lot of settings, but I think this sudden shift in print quality after - I don't know maybe - 30% of the layers for BOTH the ratchet AND the turnkey - it's very strange ... and has this anything to do with "Max comb distance" - I see no connection there ?
Notice I did NOT change anything in the profile from the RED to the GREY ratchet !
No one knows anything here ?
- 4 weeks later...
I've been away for a while but now I'm back and want to get on with 3D-printing ... but first I have to find out, what is wrong !
Because I did NOT change anything from the RED (fine and OK print !) to the GRAY ratchet (useless print !) I don't think I should change any 'settings' - and later I did delete ALL my profiles and use the
WHat I HAVE done right before the problems started is cleaning the extruder - when I put it all together again I maybe changed a little of the position of the TIP of the nozzle compared to the BED.
I therefore did a MANUAL levelling of the bed 3-4 times and then did a automatic levelling in the menu BUT do I need too to somehow 'reset' something concerning the "Home-position" in the SW ?
- 2 weeks later...
I had to print a file with this G-code in it:
M502
M500
M501
then do a manual and an automatic levelling - WHY - I don't know - but it worked !
tinkergnome 927
7 minutes ago, ksor said:I had to print a file with this G-code in it:
M502
M500
M501
So, essentially you performed a factory reset on the printer - and now it's working again?
That means it was completely unrelated to the Cura update? Phew - that's life! 🙂
Thanks for reporting back!
If you read my last 2-3 postings you'll see I too cleaned the nozzle and MAYBE put it together a little different so it's a little shorter/longer - but that it should have THIS effect is strange I think - TOO I upgrated Cura and now I did it again - updated to 4.4.0 - never do more than ONE change a a time ... but I did and now it works.
- 1
johnse 31
In order to get any reasonable help with this it would be best to post a 3mf project file (in Cura, with the model loaded and settings like you are ready to print, use File.Save (not Export) to save the file).
