For the UM3 it is enabled per default, the S5 has it disabled per default. So if you print a skirt around your object it is not really needed to have also the prime blob, but it doesn't bother me, so I don't really care about it and on the other hand a little more priming before the start always helps.
Smithy 1,145
It is called Prime Blob and ensures that your nozzle is primed before starting the print. You can turn it off if you want in the Cura custom settings.
Pia92 0
Thanks a lot! Now that I know what it is called, I find a lot about it 😀
