Posted · I cannot see the start gcode or stop gcode in machine settings
Running Cura 4.3 on Win 10 64 bit OS
I need to edit the start gcode to change ESTEPS on my Ender 3. I am changing to a BMG extruder and the start gcode box is too small to even see a whole line and
I am not a fan of reloading firmware to make the changes.
I saw some other posts on this but no fixes.
I tried messing with resolutions for the display and nothing helps. I tried it on my work laptop running the same OS and it does the same thing.
I suppose I could switch to a different slicer, but Cura has worked well for me so far and I really don't want to take on a new piece of software.
If someone has an actual fix or workaround I would appreciate the help.
Thanks for listening.
    I finnally woke up and realized I can expand the machine settings window and TADAAAA!!!
    The Start and End gcode magically appears.
