Bottom layer issues on PVA support
JDE23
Posted · Bottom layer issues on PVA support
Hi all,
I'm having issues with the bottom layer peeling when printing on a PVA support structure - see photos attached. Can anyone suggest what is causing this issue, and how I might solve it?
Thanks!
Josh
    If you look at the layer-view in Cura, I suppose it shows support in those areas?
    If so, it looks like there was no support at all in the areas where the spaghetti occured? Maybe the PVA-nozzle clogged and stopped extruding PVA, or there was huge underextrusion? (Too wet PVA?)
    But I don't have a printer with dual extrusion, so I can't give much suggestions for handling.
