thin wall Jobs display and print as solid objects
super811
Posted · thin wall Jobs display and print as solid objects
Out of the blue most but not all vases, cups and other hollow objects are showing up in Cura as solid and when sliced print as a solid object. I tried completely removing cura along with profiles and reinstall but no joy. This is happening on my other computer also.
    My Cura has magically reset some settings before when trying to print  pots, vases etc... If you haven't already you can double check these settings: Top Layers (should be set to 0); Infill (set to 0); Print thin walls.
    @super811 - what cad software are you using?
    First look at the settings in mesh fixes.
    Secondly, if this is not your model, it's actually normal to design a solid vase like this and expect people to fool with the settings.  You probably want to check the "spiralize" checkbox which is designed to turn solid vases into vases with sides and a bottom but no top.  Read the comments about spiralize (hover over the feature for a popup that describes what it does).
    Spiralize is meant for vases and cups mostly.
    Problem is I have printed this object several times and it was fine now all of a sudden it wants to display and print as a solid object. Other files that display correctly also print correctly.
    Is this object on thingiverse?  did you design it?  Can you post an STL file somewhere?  Or even better, do a "file" "save" from cura and post the 3mf project file somewhere.
    It looks solid in "prepare" mode so I'm pretty sure it will be solid in "preview" mode as well unless you tweak settings in cura (for example enable spiralize but there are other ways as well).
