I don't see how vibrations could cause this? Unless there would be some mechanical defect, such as motor, gears or belts being blocked or so dirty that it hinders their free movement. This could cause abnormal sounds indeed. But a sort of "robotic singing sound" in diagonal lines is normal.
On the condition that these are not the very first layers on top of empty gaps (above infill or hollows), as Smithy says, I would guess: underextrusion, too low temperature or too high speed, not 100% infill selected (e.g. 90%), too much friction in the filament or feeding traject, dirty nozzle hindering the flow, worn-out teflon coupler (UM2), or less likely and if the lines are in pairs: too much play in the rubber belts?
What if you do a small test cube at low speed, at 100% infill?
Smithy 1,111
On your photos it looks like this so it would be the first layer after the infill. In this case it would be normal that you have holes in this layer. The filament is held by the infill, but you get a gapless surface only after 2-3 layers.
Or does the problem also occur later, that is not so obvious?
I don't think vibrations do that. But I can't judge the noises like that, maybe you can make a video where you can hear it?
