tinkergnome 927
28 minutes ago, ScanHD said:is anybody able to say which lines of code it is that i should be adding?
G280 is responsible for the initial material feeding. The additional parameter S1 prevents the "blob".
It should be sufficient to substitute lines 31 - 32
for reference:
- 1
ahoeben 1,992
A .ufp file is "just a zip". You can open it in a zip program (eg 7zip), extract the actual gcode file to edit it, and put the edited file back in the .ufp file.
ScanHD 32
Thanks so much, i had no idea it was a zip file!
i opened with 7zip and compared the gcode....
screenshot betow for clarity..
Thanks in advance
