Hi Geert_2,
thank you for your input but maybe my previous post was not too understandible. I will try to be more exact:
1. I´ m not trying to build something complicated like a flow-sensor or something in this direction. (although I know as of today that someone can introduce an S5 flow-sensor to an U3, but that needs to trigger some sofware-update and I´m far away of reprogramming the software api).
2. There is one simple measuring device --> the laser!
A) The laser connects to the reflector on the other side --> Printer stops for pausing...
B) No passthrough --> no connection --> printer is not disturbed
3. The laser is (will be) connected to or an arduino or better a rasberry because of the preinstalled LAN-connection and programmed so if the laser connects the machine is said to stop.
4. Today I have been to the "formnext" in Frankfurt and I talked to a software-engeneer of ultimaker. He told me the prgram of the ultimaker can be paused and the comand for it can be found directly in the api of the printer. Nonetheless I left my card there so maybe he will help me out with the exact command. If not I will try my luck in the couple of the next days.
5. Anyhow the printing of the filament-trap is pretty easy and I´ m sure I will have a box ready by the end of next week.
6. The probelm is, that I don´ t know anything about programming but there might be someone out there that already did program with e.g. pyhton or anything that can be uploaded to a rasberry and started witht the laser diode hooked on it as a trigger-switch.
So in this case I would need some support in programming as I would contribute the holding device for the laser and the box.
If that runs wel´ ld have a low cost and efficient way of stopping the printer if any bowden runs out of filament.
Greetings
Daniel
geert_2 557
The problem is that systems with sensors and wires on rotating stuff are prone to all sorts of errors: false positives, and not correctly detecting real amounts, due to the spool rotating and the "sensor window" being covered by that rotating spool. These things will complicate the situation.
But recently there was a post of a guy who printed labels with a measuring scale showing the remaining amount. Then he glued the labels to his spools. The idea was similar to the scales on glass bottles and measuring jars in the kitchen. This actually is a nice and simple solution, I think. It should have been standard on all spools, since it can easily be injection moulded into the spool. But I don't remember that guy's name. Maybe you can find that thread for ideas?
