Thanks a lot, saying clearance do you mean like step of calibration? It would be great to get a screengrab of the settings you mentioned. Again, many thanks
Clearance would be distance from one thing to another.
So if you are trying to make these 2 things go together, there needs to be a certain distance between the print at all points in order for it to do that.
Try to do a cut view of the part if possible and you'll be able to see if the walls touch at any point.
When designing bolts and nuts, you run into this clearance thing, and that's how I normally do it.
Smithy 1,145
You have to consider some clearances in your 3D model and then print slow and as cool as possible.
A cleareance of 0.2mm on each side is a good starting point, for the UM3 you could also try 0.3mm first.
Set all speeds to the same value helps also a lot (infill, outer wall, inner wall) and set the jerk speeds also the the same value.
Print with 30 or 35mm/sec
For the height (Z direction) I would use even more clearance of 0.5mm or something like that.
