I had some hair like strands get wrapped around the shaft of the fan and that caused the fan to quit working. I used a fine tip tweezers to pull it out.
I pulled the fan connector out, and connected a 5v power supply to the fan. As soon as I gave it power, the fan spun up. So, I'm confident that the fan side wiring harness and the fan itself are both fine.
I then reconnected everything and brought both print cores up to 150 degrees. The display on the font of the S5 appears to read the temperature correctly, but even after several minutes, the fan didn't come on. Is there another part I could look at?
If the fan works standalaone, you could check the voltage on the connector when the cores are hot, check for 5V dc.
Maybe it is the wiring, maybe even the motherboard.
In my case, it was a blocked fan. I cleaned all the mess out, and everything worked fine again. (took me some time to find out why this machine gave me troubles)
Smithy 1,134
The front fan is for cooling the hot end and is enabled automatically when then print core is over 40°C, you cannot control the fan from Cura.
If the fan is not running then check the cables, maybe they are broken or the connector. Another reason could be that some material is blocking the fan,
