I have tried everything I can possibly think of and I can not for the life of me get this thing to print anything other then the preloaded files. I have tried 3 different versions of cura (including the one that came preloaded). I have copied and pasted gcode from everything I can find. Any model I load to the printer goes from 0% to finished in a matter of seconds, the printer makes a tiny movement (it is small and I cannot tell the direction) then is says print finished. Any help would be greatly appreciated.
I am currently on Cura 4.4, windows 7 64 bit, with the Anet ET4 printer.
kooljb09 0
Yes I was looking also and found someone saying that they used the creality CR10 Pro S printer in cura and changed the build size and so I tried it and it worked. Its all in the start and end G code so after I verified that it worked I had already set up profile that I just copied the start and end codes to my profile and then deleted the CR10 Pro S as I don't have that printer but you could just keep that one and the build side and your good to go.
