Think it's this one; (ultimaker part 8247). Don't think Ultimaker resellers will have it on stock, but you can try @MakerPoint they may have it.
picture of other feeder parts here;
1
47 minutes ago, ultiarjan said:Think it's this one; (ultimaker part 8247).
The Ultimaker part number is 1974
It's a "Stainless steel miniature ball bearing 8x12x3.5 mm" to give you a search term.
Also known as "MR128 ZZ", commonly used on RC-cars.
Good luck!
Perfect! Thank you very much for the quick answers!
Edited by huub8
gr5 1,968
You're supposed to contact your reseller. Even if they don't list parts on their website, ALL parts are available.
But if it were me I would just buy that bearing on ebay. These are standard bearings - you only need to know 3 dimensions, width, inner diameter, outer diameter. They are almost always integer numbers of mm (for example 3mm, 8mm, 12mm). So you don't have to measure them super accurately (within 0.5mm should be good enough).
