Cura 4.4's cryptographic library
Hanabi-san
Posted · Cura 4.4's cryptographic library
Hallo
I've heard, that Cura 4.4 has a cryptography library integrated. However, I am unable to find this library in Cura's lib folder. Could someone tell me, how Cura's cryptography library is called and which import statement I could use to use it in my self-written Cura plugin?
Thank you!
    @ctbeke Thank you for your fast reply. I tried using the import statement like in your example, but it does not seem to work. When I checked inside my Cura 4.4.1 application's UM folder inside the lib folder, there exists no Trust.py file. Could it be, that so far the cryptography library is only integrated in the Uranium Github repository but not in the downloadable application of Cura 4.4.1?
