Sequential part prints
mtnbkrrick
Posted · Sequential part prints
Hello,
I have a need for manually printing a support in spiral mode 1st for speed, then printing a second part inside that part for speed without jumping back and forth.  Our extruder will handle the height and clearance for doing these separately.  Without having to splice gcode together manually, is there a way to do this all within cura?
Thanks
    I do not think there is a setting for this. Maybe try to use the print sequence option (one at a time) and tweak this a lot to coop with the small tolerances? This in combination with loading them in as separte stl's might work, but i highly doubt it.
