Thanks for checking. I doubled value and it still shows up in the gcode. Spiralize mode or standard, same thing...Its definitely not every layer, which is even weirder. Its almost like it hits a volumetric limit for the E value and resets throughout the whole code.
Thanks again for offering up a possible solution. You never know what small change can help sometime. Ill keep looking.
tinkergnome 922
Cura resets the e-coordinate on every layer AFAIK - and i guess what you noticed here is something similar for the "spiralize" mode. I'm pretty sure that's not the root cause of the shown problem though...
The recommendation in this video may be the solution:
