Thx for the response Framar. I've included a picture of Layer one and only part (just over half) of layer two. Blue number one represents the very first layer - the fans were not running. Yellow number two represents Layer two which began on the left side on a crosshatch pattern and that is when the fans started to spin. I aborted so I could take this image of first and partial second layer. the first layers are terrible and so you can see why I'm assuming there is some sort of over hang issue at the buildplate.
I'm including machine settings also just in case there is some issue there: I'm also printing this with 1.75 mm plastic on .06mm Extra fine setting with 20% fill.
I'm also including image of the top of the print for reference so you can see all the layers above the first two are great . I have leveled the bed to be sure and turned off the option to generate support. So if it's not support that is being printed at the buildplate - what is causing the poor printing of the first couple layers?
Framar 39
It's the same behavior in 3.6. The bottom flat surfaces are shown in red. If you look at the first layer, does Cura print support or bottom layer???
