Thank you for the quick answer.
The Z-Axis was blocket while going down after the print. There was a Failure Screen with "Z-Axis blocked..." when I came home.
After one print.....Bevore this print I cleaned the printer to prevent this case....but obviously this didnt worked 😄
Why also doing this after the print?
And why doing this as soon as the print have started and not waitung till the Bed is heated up?
When the bed should have 110 degres the print head is very long at temperature while waiting for the bed ist at temperature.
Whats about this: Print a little tower in the build plate instead of extruding into the room. Or maybe choose between this two options in the settings?
And can i turn off/dimm the light in the Material Station?
Edited by Jonas98
More Questions..
SandervG 1,522
Hi, thank you for your message.
Is the filament 'just' wrapped around the Z axles or is it actually blocked onto a level that it prevents it from rotating properly?
The reason why it purges the material is to ensure that any material used previously has been removed from the inside of the nozzle and to prime the new material to make sure a solid first layer can be printed. There is also some calculated movement in the material and printhead to make sure it actually falls off besides your build plate to make sure it is not being dragged onto the build plate and interfere with your first layer. All so that you should be able to safely and reliably start a new print remotely.
Obviously it shouldn't wrap around the Z axles and you may just have been quite unlucky.
Did this happen after a single start of a new print or multiple?
