Hi. Thank you for your quick reply.
I am currently working with Cura 4.2.0
The 3mf file is attached.
Just sliced this in 4.4.1 and couldn't replicate the issue. It's possible that whatever has caused this has been fixed between versions, so could you try updating to the latest version to see if you get the right results?
3MF sliced in 4.4.1 attached for reference.
Sure thing. I will let you know how that works out for me. 😉
Alright i installed 4.4.1 but my problem persist.
I am pretty sure that my settings in Cura are off but i can't seem to figure out witch setting could have such influence to my object.
I will add the obj file. Perhaps you can see something i have overlooked.
I think i have figured it out. In "Experimental", "make overhang printable" was checked.
After i turned it off, the extra geometry disappeared.
Thanks for the effort anyway.
In two years have they made this option better?
Edited by DavinaI think that option is pretty useless. I don't think there is any way they could actually make a "make this printable" feature that was even 1/1000 as smart as a human. At least I can't foresee anyway to do this without human level AI.
Guest maht
Strange. Which version of Cura is this happening in?
Could you send a 3mf (go to File > Save... in Cura) and attach it here, I can then try and replicate this.
