Is Shell thickness Problem solved!? I dont believe...
Try printing an Object with Shell thicknes of 2mm in Cura 3.10 and compare it with 3.11. It's not working correctly...
Looks the same to me. Are you using the same nozzle diameter on both?
Hi Daid
The Settings are both the same... I tried several Settings and none gave me the desired Result. Cura 3.11 does not respect the Setting "Shell thickness" like Cura 3.10(RC1) does. I'm currently only using Cura 3.10 because of these Problems.
I forgott... I always use a multiple of the Nozzle Diameter for the Shell... (so it's 2.4mm, not 2.5mm)
If this is really a Problem... why not "autoadjust" the Value to the next lower valid Value, which is a multiple of the Nozzle Diameter?? There ale already Values that give YOu Feed Back when a Value is not correct/valid...
If you guys are going to report a bug Daid is more likely to look into it if you provide a screen shot of the layer view that demonstrates the problem along with explaining what you set nozzle size and shell to. If you make a little extra effort, then maybe Daid will also.
This.
You're putting a lot of guess work for me here. You just went from 2.0 mm to 2.4 or 2.5, your problem description is vague ("not working correctly" without telling what "correctly" is in your view)
You're also acting like it's a well known problem, while it's the first I heard about it.
Sorry. I wasn't following this thread.
Here is a screenshot of Cura slicing the 0.4mm calibration box from this thing:
http://www.thingiverse.com/thing:52946
(i have stopped pursuing this routine since it doesn't apply when using Cura)
This should be a box with four walls instead of three.
I used 0.4mm Nozzle diameter and 0.4mm shell thickness.
Here is my complete profile. Just in case you need some other value:
[profile]
layer_height = 0.2
wall_thickness = 0.4
retraction_enable = True
solid_layer_thickness = 0.9
fill_density = 100
nozzle_size = 0.4
print_speed = 50
print_temperature = 210
print_temperature2 = 0
print_temperature3 = 0
print_temperature4 = 0
print_bed_temperature = 55
support = None
platform_adhesion = None
support_dual_extrusion = Both
wipe_tower = False
ooze_shield = False
filament_diameter = 2.85
filament_diameter2 = 0
filament_diameter3 = 0
filament_diameter4 = 0
filament_flow = 100.0
retraction_speed = 40.0
retraction_amount = 4.5
retraction_dual_amount = 16.5
retraction_min_travel = 1
retraction_combing = True
retraction_minimal_extrusion = 0.1
bottom_thickness = 0.3
object_sink = 1
overlap_dual = 0.2
travel_speed = 150.0
bottom_layer_speed = 30
infill_speed = 80
cool_min_layer_time = 5
fan_enabled = True
skirt_line_count = 1
skirt_gap = 3.0
skirt_minimal_length = 150.0
fan_full_height = 0.5
fan_speed = 25
fan_speed_max = 66
cool_min_feedrate = 0
cool_head_lift = False
solid_top = True
solid_bottom = True
fill_overlap = 100
support_fill_rate = 15
support_xy_distance = 1.5
support_z_distance = 0.2
spiralize = False
brim_line_count = 20
raft_margin = 5
raft_line_spacing = 1.0
raft_base_thickness = 0.3
raft_base_linewidth = 0.7
raft_interface_thickness = 0.2
raft_interface_linewidth = 0.2
fix_horrible_union_all_type_a = False
fix_horrible_union_all_type_b = False
fix_horrible_use_open_bits = False
fix_horrible_extensive_stitching = False
plugin_config = (lp1
object_center_x = -1
object_center_y = -1
[alterations]
start.gcode = ;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
G1 F200 E3 ;extrude 3mm of feed stock
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing...
end.gcode = ;End GCode
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
M84 ;steppers off
start2.gcode = ;Sliced at: {day} {date} {time}
;M104 S{print_temperature} ;Uncomment to add your own temperature line
;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line
;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
T1 ;Switch to the 2nd extruder
G1 F200 E10 ;extrude 10mm of feed stock
G1 F200 E-{retraction_dual_amount}
T0 ;Switch to the first extruder
G1 F{travel_speed}
M117 Printing...
end2.gcode = ;End GCode
M104 T0 S0 ;extruder heater off
M104 T1 S0 ;extruder heater off
M84 ;steppers off
support_start.gcode =
support_end.gcode =
cool_start.gcode =
cool_end.gcode =
replace.csv =
switchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
G92 E0
G1 E-36 F5000
G92 E0
T{extruder}
G1 X{new_x} Y{new_y} Z{new_z} F{travel_speed}
G1 E36 F5000
G92 E0
Daid 305
Cura cannot slice the 0.4mm thin wall properly, that's a known problem. It's due to rounding in the engine.
