Cura 13.11 - shell-thickness = nozzle-diam.
jumpmobile
Posted · Cura 13.11 - shell-thickness = nozzle-diam.
Hi
I have discovered a problem in Cura 13.11:
When the nozzle diameter equals the shell thickness the slicer does strange things like leaving out walls on the 0.4mm test cube ( http://www.thingiverse.com/thing:52946 ) or making no walls at all...
Workaround: set the shell thickness to 3.99 instead of 0.4.
    Is Shell thickness Problem solved!? I dont believe...
    Try printing an Object with Shell thicknes of 2mm in Cura 3.10 and compare it with 3.11. It's not working correctly...
    Looks the same to me. Are you using the same nozzle diameter on both?
    I forgott... I always use a multiple of the Nozzle Diameter for the Shell... (so it's 2.4mm, not 2.5mm)
    If this is really a Problem... why not "autoadjust" the Value to the next lower valid Value, which is a multiple of the Nozzle Diameter?? There ale already Values that give YOu Feed Back when a Value is not correct/valid...
    If you guys are going to report a bug Daid is more likely to look into it if you provide a screen shot of the layer view that demonstrates the problem along with explaining what you set nozzle size and shell to. If you make a little extra effort, then maybe Daid will also.
    This.
    You're putting a lot of guess work for me here. You just went from 2.0 mm to 2.4 or 2.5, your problem description is vague ("not working correctly" without telling what "correctly" is in your view)
    You're also acting like it's a well known problem, while it's the first I heard about it.
    Sorry. I wasn't following this thread.
    Here is a screenshot of Cura slicing the 0.4mm calibration box from this thing:
    (i have stopped pursuing this routine since it doesn't apply when using Cura)
    cura leaving out walls
    This should be a box with four walls instead of three.
    I used 0.4mm Nozzle diameter and 0.4mm shell thickness.
    Here is my complete profile. Just in case you need some other value:
    [profile]
    layer_height = 0.2
    wall_thickness = 0.4
    retraction_enable = True
    solid_layer_thickness = 0.9
    fill_density = 100
    nozzle_size = 0.4
    print_speed = 50
    print_temperature = 210
    print_temperature2 = 0
    print_temperature3 = 0
    print_temperature4 = 0
    print_bed_temperature = 55
    support = None
    platform_adhesion = None
    support_dual_extrusion = Both
    wipe_tower = False
    ooze_shield = False
    filament_diameter = 2.85
    filament_diameter2 = 0
    filament_diameter3 = 0
    filament_diameter4 = 0
    filament_flow = 100.0
    retraction_speed = 40.0
    retraction_amount = 4.5
    retraction_dual_amount = 16.5
    retraction_min_travel = 1
    retraction_combing = True
    retraction_minimal_extrusion = 0.1
    bottom_thickness = 0.3
    object_sink = 1
    overlap_dual = 0.2
    travel_speed = 150.0
    bottom_layer_speed = 30
    infill_speed = 80
    cool_min_layer_time = 5
    fan_enabled = True
    skirt_line_count = 1
    skirt_gap = 3.0
    skirt_minimal_length = 150.0
    fan_full_height = 0.5
    fan_speed = 25
    fan_speed_max = 66
    cool_min_feedrate = 0
    cool_head_lift = False
    solid_top = True
    solid_bottom = True
    fill_overlap = 100
    support_fill_rate = 15
    support_xy_distance = 1.5
    support_z_distance = 0.2
    spiralize = False
    brim_line_count = 20
    raft_margin = 5
    raft_line_spacing = 1.0
    raft_base_thickness = 0.3
    raft_base_linewidth = 0.7
    raft_interface_thickness = 0.2
    raft_interface_linewidth = 0.2
    fix_horrible_union_all_type_a = False
    fix_horrible_union_all_type_b = False
    fix_horrible_use_open_bits = False
    fix_horrible_extensive_stitching = False
    plugin_config = (lp1
    object_center_x = -1
    object_center_y = -1
    [alterations]
    start.gcode = ;Sliced at: {day} {date} {time}
    ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
    ;Print time: {print_time}
    ;Filament used: {filament_amount}m {filament_weight}g
    ;Filament cost: {filament_cost}
    ;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
    ;M109 S{print_temperature} ;Uncomment to add your own temperature line
    G21 ;metric values
    G90 ;absolute positioning
    M107 ;start with the fan off
    G28 X0 Y0 ;move X/Y to min endstops
    G28 Z0 ;move Z to min endstops
    G1 Z15.0 F{travel_speed} ;move the platform down 15mm
    G1 F200 E3 ;extrude 3mm of feed stock
    G92 E0 ;zero the extruded length again
    G1 F{travel_speed}
    ;Put printing message on LCD screen
    M117 Printing...
    end.gcode = ;End GCode
    M104 S0 ;extruder heater off
    M140 S0 ;heated bed heater off (if you have it)
    G91 ;relative positioning
    G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
    G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
    G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
    M84 ;steppers off
    start2.gcode = ;Sliced at: {day} {date} {time}
    ;M104 S{print_temperature} ;Uncomment to add your own temperature line
    ;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line
    ;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line
    G21 ;metric values
    T1 ;Switch to the 2nd extruder
    G1 F200 E10 ;extrude 10mm of feed stock
    G1 F200 E-{retraction_dual_amount}
    T0 ;Switch to the first extruder
    G1 F{travel_speed}
    M117 Printing...
    end2.gcode = ;End GCode
    M104 T0 S0 ;extruder heater off
    M104 T1 S0 ;extruder heater off
    M84 ;steppers off
    support_start.gcode =
    support_end.gcode =
    cool_start.gcode =
    cool_end.gcode =
    replace.csv =
    switchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
    G92 E0
    G1 E-36 F5000
    G92 E0
    T{extruder}
    G1 X{new_x} Y{new_y} Z{new_z} F{travel_speed}
    G1 E36 F5000
    G92 E0
