What is happening here?
LouisVLONE
Posted · What is happening here?
Hi so I've modeled this in blender. And I ran into this weird thing in cura once again. It seems pretty ok at first but as soon as I place one support blocker like I did on the second pic it will randomly fill up those holes. The rest of the print/model is untouched just those things. I've encountered this just with my last print where I wanted to print a thread. As the hole looked up cura filled the hole completly from the ground up. But if I rotated it so that the hole was horizontally cura decided to print the object as shown on the model. And I really need support blockers since cura will create tons of support which are way to far connected so it would destroy the print.
How do I fix this issue?
I really need support. ;)))
Also attached the stl file.
first pic: normal slicing
second pic: same as before but with one support block placed somewhere
FlowerPot3.stl
    Wow ok danke. Jetzt funktioniert es wirklich! Aber nur noch damit ich weiß woran es lag: Was war denn falsch/was hat diesen Fehler genau verursacht. Ich habe ja selbst noch mal ein bisschen repariert und hatte trotzdem diesen Fehler.
    Und wie gesagt hatte ich letztens diesen Fehler auch von einem gut bewerteten Thingiverse Objekt.
    LG und vielen Dank!
