What is happening is that the model is broken/unsuitable for 3d printing. I'm guessing the model has infinitely thin walls, ie the walls show white on one side and blue-ish on the other (in sketchup; did I guess correctly?). All walls need to have thickness to be printable, or Cura will get confused about being inside the wall or outside the wall.
burtoogle 505
Hi, I don't think we can help you unless you can provide further info. Please attach the project file (.3mf) so we can see what is happening and suggest a remedy. Thanks,
