tinkergnome 929
On 2/14/2020 at 1:01 PM, Dim3nsioneer said:There is a drying unit based on dessiccant that is regenerated regularly inside the Material Station. You do only see the exhaust on the back and a small opening inside filament compartment.
Are those things not explained in the manual?
@A3000T dunno if this is related in your case, but be aware that the material station is an "always on" unit, like a refrigerator. Never cut the power - at least not while sensitive materials are stored in it.
Dim3nsioneer 559
Best thing you probably can do is to put a small hygrometer inside the compartment. You should see humidity drop within minutes (unless your enviroment is already very dry).
Edited by Dim3nsioneerLink to post
