S5 ER999
Sandi
Posted (edited) · S5 ER999
Update. Error ER999 occurs at every new layer.  After finished layer head travels to starting position and from there back and begins printing new layer. At this time ER999 occurs.
Edited by Sandi
    Posted · S5 ER999
    Let's close this topic. I changed the firmware and Cura version while error 999 was persistent. The local reseller spent several hours and did not find the cause. After that, I removed all Cura versions and stored profiles. After new Cura installation, there was a warning about corrupt profiles. ER999 disappeared.
    And now I have some new info to look at, thanks!
    That said we've made s serious error to squash ER999/ER998 and other reasons to get certain ER screens in the new version 5.6.x
    I get this code when using the "change at Z" g code mod. Does not seem to bother too much.
