Posted
· How to remove Air Manager "mounting bracket"?
Never mind... figured it out.
You can remove the mounting bracket by sliding a knife blade up between each of the two metal clips in the middle of the bracket and the S5 while pulling gently up. Slide all the way until you hear a release, then do the other clip. DO NOT FORCE!
wyojustin 1
