6 hours ago, JCD said:Have you tried to lower the support flow in this case, something like 90% instead of 100% ?
It will maybe give you support slices a little thinner. This may make the support less strong, but if this is is the case, the support blocker maybe the trick, allowing you to do this only near the top of the support
First, thanks for the suggestion JCD, I will likely give this a try. I still believe that Cura should have the support for z-gaps that are not a multiple of the layer height but will try any work arounds I can find. Much appreciated.
JCD 28
