3 hours ago, burtoogle said:Increase the filament diameter so that will reduce the extruded lengths for lines.
If you meant "compatible material diameter", this didn't have any effect.
But I solved this by adding command M92 to the start of my gcode. (Reseting printer will return extrusion setting back to normal.)
Info for other zmorph VX paste extruder users through Cura:
Right now I'm using code M92 E11 in the start of gcode with a flow setting of 45%.
This is with original 100ml syringe and 2mm nozzle.
Thank you for answers!
1
burtoogle 516
