Sorry, I don't know the answer to your question but in that regard, my releases should be the same as the recent UM releases. So if it is true for them, it will also be true for my releases.
8 hours ago, burtoogle said:my releases should be the same as the recent UM releases
One major difference is that the Ultimaker releases all use a different configuration folder per version, so you can keep different versions of Cura installed and they do not interfere with eachother. Your builds (as far as I know) all use the "master" folder, so once you used a newer version of your builds chances are older versions of your builds will no longer be able to use the same settings because those have been upgraded for a newer version.
You probably mention that in the readme, but since using different versions next to eachother is the subject of this thread, I thought it would be worth a mention.
That's a good point. I don't think I mention that in my README so I'll add a comment.
Personally, I keep all of my configuration files in a git repo and every now and again I make a snapshot so I can recover if anything gets trashed. I have had to rewind a few times due to upstream changes causing breakage but that's the price to pay for living on the edge....
burtoogle 505
Hi, my Cura builds are based on the most recent code from UM and you can install my builds alongside the UM releases. If you are interested you can find them at https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AAADdYdSu9iwcKa0Knqgurm4a?dl=0
Please read the README.md file there before using.
nallath 1,063
Installing Cura 3.4.1 and Cura 4.5 side by side should be possible.
JohnInOttawa 99
Thank you both.
@burtoogle, thanks for sharing your link. One question - do I need to upgrade my firmware to the latest version in order to use your updated Cura load?
Much appreciated.
John
