Posted · Layer problems in Model on bridging layers
Hey Guys,
I just started messing around with the bridging setting of cura, and I came across an interesting issue.  The part looks really good until it prints the layers that would be considered bridging layers.  I printed a couple of different models, and it always occurred at the bridging layers.  I looked at the layers in Cura and it appears that the layers that are messed up, still have the same flow rate as the rest of the model, but it just looks bad.    I have tried adjusting the coasting setting, but that does not seem to help.  I was hoping someone could shine some light on the issue.
here is the printer information:
Ultimaker 2
3d fuel PLA
50 mm/s print speed I slow the outer wall speed to 20mm/s instead of the default
205 print temperature
Bondtech QR feeder
Olson Block
Please let me know if you need any other information.
