Here's the STL that I'm trying to import.
Completely sub-conscious. I'm not sure that a single finger is considered that offensive in the UK, we've always preferred the two-finger version.
The problem is, I specifically want it to be "not watertight". I need access to the pins, that are inside the object.
"Watertightness" doesn't require the model to be completely solid, you are allowed to have holes. What it does require is that all the surfaces join up with no gaps. It should be possible to fill the internal volume of the model with liquid without it leaking out between the model's polygons.
I understand the problem. It's not a watertight solid. I found a way to import it somewhat fine using meshmixer to create a hollow with an offset which makes the outer Hull actually have a thickness to it. Now the problem is, that's not really what I want. The result in cura now can't be printed with infill since the actual inside of the model is only within the walls. Also cura sees both sides of the wall as outer Perimeter. I understand the problem but actually am looking for a way to just prevent printing part of the regular model's wall.. In other words: I would basically like to set the whall line count to zero in that particular area. I just tried to use the support blocker and "Modify settings for overlap" but that doesn't do anything.
burtoogle 505
The most likely reason is that the model is not valid. Could you please attach the stl file to this thread?
