Technically you could probably print this using FDM if you used a smaller nozzle such as 0.25. But I'm guessing the surface quality is quite important on these so SLA might be a better bet. If I were to print it using SLA I would try printing it straight on the platform without supports. It's not the way it "should" be done, but I think it could work.
If you do it correctly and tilt the model and add supports I think there's a good chance you could damage the blades when removing the supports since they are so thin.
Also, I think you need to fix your model because the blades are not attached to the walls.
- 1
IRobertI 520
At this type of scale you're not going to be able to do it with an FDM printer like an Ultimaker. You're going to need to go with an SLA printer or something similar. But yes, with the right type of printer you'll be able to print this.
swish_31 1
Thanks for the answer sir.
i wanted to know, as in SLA printing there are generally lots of support structures, how will i be able to remove those from under the blades as my entire product is really extremely small.
Will this product be possible in SLA without supports?
I am attaching my STL file for your reference.
Another thing, also is there no possibility of this being printed on a FDM printer.Main body MK4.stl
Thanks
