7 minutes ago, gr5 said:Those are non extruding moves so the head can get from one part to the other.
In your screen shot I can see you have near the top "color scheme" set to "material color". I prefer to set that to "line type". Then note that you can check and uncheck different things. If you uncheck "travel moves" those lines should go away - which might be bad as then you can't see them but they are still there.
Note that it shows one blue color but in fact there are 2 shades of blue - light blue, dark blue. One color indicates that there was a retraction before the move. The other indicates there was no retraction. This matters. non-retraction moves will leak a bit.
I changed it to line type, travels is not selected, its showing red as shell.
Edited by Catevari
gr5 2,004
