tryed switching out M190 R43 with G4 P300 but it now just ignored the command and went straight to pushing the print off the bed witch it could not. Nothing broke since i was ready for it.
Ill search for more option tomorrow so if anyone else have a suggestion id appreciate it .
EDIT. and 1 second after posting i realised that P is milliseconds.. i should have used S... ill try agian tomorrow
Edited by Ettuf
tinkergnome 927
It's just a guess, but i assume the R parameter for M190 is not supported by the UM3.
That means the Ultimaker can't wait for the target temperature during cooling.
The best alternative is probably to add a few minutes pause with the G4 command. You have to test first how long it usually takes to cool down to the target temperature though.
